| How do you tell if you have a Rake Adjustable Casting http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=41061 |
| Author: | bryan b [ Tue Jan 31, 2012 4:39 pm ] |
| Post subject: | How do you tell if you have a Rake Adjustable Casting |
I just got a set of EPO2's for my boat and I want make sure thy they are drilled corectly and there is a spec for adjustable and non adjustable. Thanks |
| Author: | mmiller [ Tue Jan 31, 2012 5:11 pm ] |
| Post subject: | Re: How do you tell if you have a Rake Adjustable Casting |
Adjustable castings have a bolt visible on the top of the upper casting. That moves a plate fore and aft on the inside of the casting. The plate trips the cam. Older ones have a pin (that trips the cam) pressed into the casting visible from either side. |
| Author: | sunvista [ Wed Feb 01, 2012 7:33 am ] |
You wouldn't think the small offset would make a big difference but it really does. I picked up a 14 Turbo with adjustable rudder arms. One of the rudders was drilled to the non-adj spec. When the rudders were locked down the non-adj rudder was nowhere near vertical and not anywhere close to being aligned with the other. If you have the older rudder arms you might want to try to find a set of newer adjustable's before drilling your expensive EPOs. |
| Author: | bryan b [ Wed Feb 01, 2012 9:58 am ] |
Does any one have a pic of what they look like or a vender that would sell them |
| Author: | MBounds [ Wed Feb 01, 2012 2:57 pm ] |
Superficially, they look identical. Look closely, though. Non-rake adjustable will have a hole on each side where the locking pin is: ![]() Rake adjustable has a bolt on the top and no hole on the side: ![]() Vendor? How about a Hobie dealer? |
