| Jib hank for coated forestay? http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=42633 |
| Author: | Mike16 [ Fri May 11, 2012 12:16 pm ] |
| Post subject: | Jib hank for coated forestay? |
The jib hank on my Hobie 16 jib sail does not fit properly on my new plastic-coated forestay. It needs to be slightly larger to accommodate the slightly larger diameter forestay. Does anyone know if larger jib hanks are available? |
| Author: | mdgann [ Sat May 12, 2012 9:00 am ] |
| Post subject: | Re: Jib hank for coated forestay? |
Just drill it out! If it breaks, it breaks. No big deal. |
| Author: | rattle 'n hum [ Mon May 14, 2012 11:34 am ] |
Or remove the forestay coating! |
| Author: | BilgeRat [ Mon May 14, 2012 8:59 pm ] |
I had the same problem and I used a round file to make it a bit bigger, seems safer than drilling. |
| Author: | Mike16 [ Tue May 15, 2012 6:52 am ] |
Thanks very much. Using a round file seems like the best plan. |
