| Gudgeon problem, last minute, help http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=43689 |
| Author: | hookey37 [ Thu Jul 05, 2012 6:03 pm ] |
| Post subject: | Gudgeon problem, last minute, help |
Okay everybody, I have races tomorrow, and my upper gudgeon broke today, the screws are still in, so the holes aren't stripped which means all I have to do is replace it, the only problem is, the store only had the lower gudgeon so what I was thinking was I just put the lower gudgeon on the upper gudgeon spot, can't be that off right? I was just nervous that the tension would be off somehow because of how the lower gudgeon is made but I can't see the problem. I just wanted a little reassurance and to see what you guys think, thanks. Hook |
| Author: | Tim H16 [ Fri Jul 06, 2012 9:57 am ] |
| Post subject: | Re: Gudgeon problem, last minute, help |
Hook, As long as the threads in the two holes through your aluminum plate are fine, a 4-holed (bottom gudgeon) will fit in the top location. You don't need to put in the top two bolts since a bottom gudgeon is basically two top gudgeons back to back. |
| Author: | srm [ Fri Jul 06, 2012 11:51 am ] |
The lower gugeon is just two upper gugeons flipped back to back and welded together. I would buy the lower gugeon and carefully cut/grind off the weld. Then you will have two upper gugeons. They won't be pretty, but should get you through the weekend. sm |
| Author: | tmason [ Fri Jul 06, 2012 6:29 pm ] |
Are you near Ft Walton Bch Florida? I have a bag full of Gudgeons, upper and lower. |
