| running a jib without battons http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=45436 |
| Author: | cavi [ Wed Oct 24, 2012 9:12 am ] |
| Post subject: | running a jib without battons |
i see many people running a furling jib so my question is how does the h16 work with a jib without battons? i only ask as it would eliminate the hassle of the jib getting caught on the mast whentacking |
| Author: | Jbernier [ Wed Oct 24, 2012 9:27 am ] |
| Post subject: | Re: running a jib without battons |
the stock sail won't work if you remove the battens, since it has a large roach leach - you need to have the sail re-cut so that the leach is hollow - otherwise it will flutter horribly. Or just get the rec jib already to go from your nearest Hobie dealer - and save the stock sail for racing. |
| Author: | cavi [ Wed Oct 24, 2012 3:38 pm ] |
how much less power will i notice with a jib that does use battons? i take it i donot have to use a furler if i do not want to |
| Author: | kdj [ Wed Oct 24, 2012 5:07 pm ] |
The battons are better. I started the summer without them on cheap rebuild 16 that I have on lake Mich. I found a set on ebay for like $40. In addition to stopping my worn out jib from trying to beat itself to death, I could feel a noticeable increase in power by the butt-o-meter |
| Author: | GD_NC [ Wed Oct 24, 2012 5:35 pm ] |
Order a set of Hobie Super Battens for your jib. They are about 1/3 the stiffness of the regular battens. Keeps the sail shape and stops the hang up problems. Not sure about overall impact on speed. I have not noticed much difference. |
| Author: | cavi [ Mon Oct 29, 2012 4:17 pm ] |
where do I get these super battons? |
| Author: | buxton [ Tue Oct 30, 2012 9:59 am ] |
Super Jib battens are from your Hobie dealer, under $40.00 for the set. |
