| Main traveler direction http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=46295 |
| Author: | phil_e [ Sat Jan 19, 2013 9:52 am ] |
| Post subject: | Main traveler direction |
I didn't note which way the traveler car faces when I removed it from the track. Is there a front and back? It doesn't look the same on both sides. |
| Author: | sunvista [ Sun Jan 20, 2013 11:36 am ] |
| Post subject: | Re: Main traveler direction |
The open side faces aft. Looks like it would work either way though. |
| Author: | phil_e [ Tue Jan 22, 2013 5:20 pm ] |
I think you are right. I tried it both ways and it seems to rest against the track better when it's tipped over (when there is lots of slack on the main sheet) this way. I thought I remember seeing something a post a while back about there being a right way this should face. |
| Author: | sunvista [ Wed Jan 23, 2013 7:40 am ] |
If you have an older boat with two block hangers on the boom I prefer to use the forward one. When I use the aft hanger the traveler seems to bind under wind load due to the lower angle. |
