| Hobie 16 Rudder Problems http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=46667 |
| Author: | robkabob94 [ Wed Feb 27, 2013 3:01 pm ] |
| Post subject: | Hobie 16 Rudder Problems |
Im sailing a Hobie 16 out of Dana Point, Ca, and have a few questions. --At high speeds, I have to pull the tiller extremely hard towards me to keep the boat going straight. Is this normal? --Also at high speeds, the rudders hum occasionally. how can I fix this. =Thanks for reading, Robert |
| Author: | Jbernier [ Wed Feb 27, 2013 4:53 pm ] |
| Post subject: | Re: Hobie 16 Rudder Problems |
FAQ Section has this info - sounds like you don't have the rudder locked into the down position to me - or they are raked back too far - need to tuck the rudders under the transom further. Here are some links for you to read: viewtopic.php?f=18&t=467 viewtopic.php?f=18&t=12859 Also the owner's manual might help explaining how to rig and sail the boat - big thing is getting the rig right and the rudders locked down (make sure your cams are functioning corectly) link: http://www.hobiecat.com/support/products/hobie-16/ |
| Author: | robkabob94 [ Thu Feb 28, 2013 12:50 am ] |
You're right the rudders aren't locked into place. Both of the cams are jammed into place. Hopefully replacing them will do the job. Thanks for the feedback. -robert |
