| Winter Storage on Angle like this??? http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=49683 |
| Author: | mmadge [ Mon Oct 28, 2013 10:57 am ] |
| Post subject: | Re: Winter Storage on Angle like this??? |
That looks like an Insurance Claim waiting to happen.Minimum I would have it tied down to those supports.Also for what little time it takes I would take the rudders off (especially if there Carbon),and if I was only planning on using it a few times I would drop mast and tie it down on boat. That is a pretty nice looking boat ,for the few extra min. Of rigging time ...... |
| Author: | sxrracer [ Mon Oct 28, 2013 11:14 am ] |
Like MM Said, at least strap it down. I would say put it bow up, this way you know you got all of the water out of the hulls. |
| Author: | SNovak [ Mon Oct 28, 2013 1:41 pm ] |
1) Definitely bow up so it will drain. You don't want to have water collect in the boat and potentially freeze. 2) Mast down if possible- if not, drop that jib/snorkel you have up in those photos- the snorkel will sit there chafing against the jib in the wind, and can fatigue the rigging from the shaking. 3) incredibly solid tie downs. a lot of the damage to Hobies in the summer is from thunderstorms flipping beached boats that aren't adequately tied down. 4) Not sure how exposed you are, but make sure you consider worst case tides/storm surge/waves in deciding if the boat is far/high enough from the water. You really don't want the 16 floating in through the glass door in a winter storm... Enjoy having the ability to sail in the winter, and make sure you dress appropriately for the water temperature (dry suit, I would assume). |
| Author: | jackB [ Mon Oct 28, 2013 6:01 pm ] |
waldorf wrote: Will the constant strain on the shrouds cause a problem??? Constant load on the shrouds is a is actually the least you should be worry about. Your shrouds are rated for static loads in order of 1000 lbs. The issue is a fatigue from wind tossing your mast back an and forth. All your standing rigging, including all the hardware connected to it, will by under dynamic and repetitive loads resulting with premature wear. This is not much different from storing your H16 with mast up year around. For this reason, the best is to store your mast in down position. As others said, a lots of tie downs is a good idea. If you must keep your H16 with a mast up, I would put a lots of bungees to restrict mast from tossing around as much as possible. BTW, I envy your location! Here in central BC, sailing season is over and otherwise winds are light. I happen to visit Sechelt last summer and I was drooling at the water properties like yours. |
| Author: | Hobie Nick [ Tue Oct 29, 2013 5:05 pm ] |
If you plan to leave the mast up you could remove the slack in the rigging to prevent the dynamic loading. Bungies will not work since they will still allow movement. You need to use regular rope. I am not sure how much snow you will get, but I would rig a cover to shed the snow instead of letting it pile up. Snow can add lots of weight to a boat. I was a dockmaster at a marina in Annapolis, MD for a few years. It doesn't snow too much, but once in a while we a got a few feet. I saw more than a few boats sink stern down that had large cockpits with no or failed covers. Granted it was wet, heavy snow, but that weight can add up quickly. Also, frozen lines are a PITA. Take all of the lines inside and rig them when needed. I do not know how cold it gets where you are, but it sounds like temps are similar to Annapolis (since you can sail in the winter). |
| Author: | hogwldfltr [ Tue Oct 29, 2013 6:47 pm ] |
Why the angle anyway? |
| Author: | waldorf [ Mon Nov 04, 2013 6:22 pm ] |
JackB... yes the winds here are quite nice... steady so you know what to expect....was out yesterday steady 10-12 winds.... thanks for your suggestions..... |
