| Tramp height http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=52756 |
| Author: | El Gato Rojo [ Tue Sep 02, 2014 4:53 pm ] |
| Post subject: | Tramp height |
Can anyone give me the tramp (top of rear frame) to water line distance with approx 350 lbs onboard? Thnx |
| Author: | MBounds [ Tue Sep 02, 2014 8:06 pm ] |
| Post subject: | Re: Tramp height |
It depends on where the 350 lbs is located on the boat. If it's all in the back, then the distance between the crossbar and the water will be pretty small. It also depends on the waves and wind. It's not a static measurement at all. |
| Author: | ronholm [ Tue Sep 02, 2014 9:23 pm ] |
MBounds wrote: It depends on where the 350 lbs is located on the boat. If it's all in the back, then the distance between the crossbar and the water will be pretty small. It also depends on the waves and wind. It's not a static measurement at all. So somewhere between zero and eight feet? |
| Author: | AntonLargiader [ Wed Sep 03, 2014 4:17 am ] |
From the top of the rear crossbar it's about 11" to the hull lip and 23" to the bottom of the hull. With two people on the boat, positioned typically, static, I'd guess it's probably about 14". |
| Author: | El Gato Rojo [ Thu Sep 04, 2014 3:30 pm ] |
ronholm wrote: MBounds wrote: It depends on where the 350 lbs is located on the boat. If it's all in the back, then the distance between the crossbar and the water will be pretty small. It also depends on the waves and wind. It's not a static measurement at all. So somewhere between zero and eight feet? That narrows it down. Flat water, weight evenly distributed front to back on the tramp. |
| Author: | El Gato Rojo [ Fri Sep 05, 2014 7:30 am ] |
Thanks Anton.....I should have been more specific, an approximation @ static is what I needed. |
| Author: | El Gato Rojo [ Fri Sep 05, 2014 3:31 pm ] |
AntonLargiader wrote: From the top of the rear crossbar it's about 11" to the hull lip and 23" to the bottom of the hull. With two people on the boat, positioned typically, static, I'd guess it's probably about 14". Perfect, thanks Anton |
| Author: | AntonLargiader [ Mon Sep 08, 2014 10:10 am ] |
You're welcome. Just remember that in use this dimension is meaningless. For me, it would be constantly varying from 10 to 25 or more, and then you have the heel of the boat on top of that. |
| Author: | ronholm [ Mon Sep 08, 2014 10:41 am ] |
El Gato Rojo wrote: ronholm wrote: MBounds wrote: It depends on where the 350 lbs is located on the boat. If it's all in the back, then the distance between the crossbar and the water will be pretty small. It also depends on the waves and wind. It's not a static measurement at all. So somewhere between zero and eight feet? That narrows it down. Flat water, weight evenly distributed front to back on the tramp. Sorry about that.. not trying to be a jerk, just that when sailing a Hobie 16 that zero to 8ft is probably closer to the truth than any static measurement, as sitting still in flat water with no wind isn't something I try and do very often. Why ya asking? |
