| Attaching Mast Cam Cleat To Mast http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=52991 |
| Author: | wingnut [ Sat Sep 27, 2014 12:03 pm ] |
| Post subject: | Attaching Mast Cam Cleat To Mast |
What hardware is everyone using to attach their cam cleat to the mast for rake/jib adjustments on the fly? I was thinking about drill and tapping but wanted to see if someone had a better/easier way. Thanks in advance! |
| Author: | Bill 404 [ Sat Sep 27, 2014 3:20 pm ] |
| Post subject: | Re: Attaching Mast Cam Cleat To Mast |
I install a cleat on my mast with a pass through long bolt and found that the tension is too great to do any adjusting...spend your money elsewhere .... |
| Author: | RHoughVYC [ Wed Oct 01, 2014 4:52 pm ] |
Bill 404 wrote: I install a cleat on my mast with a pass through long bolt and found that the tension is too great to do any adjusting...spend your money elsewhere .... Don't change the rake when the halyard is under tension. Make the adjustments as part of a mark rounding when the mainsheet is eased. |
| Author: | Cosmicsedso [ Thu Oct 02, 2014 7:57 pm ] |
I have just purchased the kit for this from the Hobie shop. Their recommendation is to drill and tap for the cam cleat and, if you didn't have a horn cleat on that side, then that gets tapped too. I have done the work but haven't test sailed it yet.... I certainly wouldn't be putting a 'through bolt' through the mast unless I could fit a spacer (very difficult) inside to stop the side walls collapsing. One thing I have found since joining the Hobie family, after nearly 50 years in Monos, is that it is much better to buy the stock Hobie parts. I expected a rip off similar to the Laser rip off but I have been pleasantly surprised. The parts are top quality, the service is sensational and the pricing reasonable. And the systems, developed in part by Hobie sailors worldwide, work really well. And where I am in AUS a 'class legal' Hobie with all the right gear is worth more in resale value. |
| Author: | h16bill [ Fri Feb 20, 2015 7:34 pm ] |
I have done a couple of these and have seen a few others done. I do the tap thing but after that I bed the Harken cleat with Marinetex epoxy to handle mounting a flat cleat on a round mast. Mask off around the cleat with masking tape. Rough up the aluminum a bit so the Marinetex will grip. Cheers Bill 2013 Hobie 16 1988 Hobie 17 1985 Hobie 14 Previous 16's owned 1981, 1986, 1993, 1995, 1997, 1999, 2000, 2004, 2008, 2010 |
| Author: | ronholm [ Sat Feb 21, 2015 8:05 am ] |
To attach the cleat I hold it in position and center punch one hole.. Drill the hole to size and then with an extra machine screw of the right size I just carefully thread it in place. Tighten it up and center punch the other hole, and do the same. I tried tapping the hole the first time I did this and it just felt like it was really hard to get the angle properly lined up, and the tap is cutting yet more material away. When you just CAREFULLY thread the machine screw in on something that thin it quickly deforms to the shape of the threads. Just be careful that a bur or something doesn't break off and foul the threads of your machine screw. I have done it this 'tapless' several times with great success. YMMV |
| Author: | h16bill [ Sat Feb 21, 2015 8:34 am ] |
Ron, Great tip. I'll try this the next time I do one which will be in the spring on a friends boat. By the way, I like your sail. Saw it at lewes DE. Cheers Bill |
| Author: | ronholm [ Sat Feb 21, 2015 8:47 am ] |
h16bill wrote: Ron, Great tip. I'll try this the next time I do one which will be in the spring on a friends boat. By the way, I like your sail. Saw it at lewes DE. Cheers Bill Thanks! I like the sail too, but it is terrible 'racing camo" Just be careful that you drill the holes as close to the angle the machine screw is going to hit. Without a good center punch dimple that can be tough to keep them from walking sometimes. |
| Author: | MVD [ Mon Feb 23, 2015 5:35 pm ] |
I haven't looked closely at this kit yet, so maybe this would be a bad idea, but what do y'all think about using stainless rivets? They're easy. |
| Author: | srm [ Mon Feb 23, 2015 6:11 pm ] |
MVD wrote: I haven't looked closely at this kit yet, so maybe this would be a bad idea, but what do y'all think about using stainless rivets? They're easy. I think you could have problems if you tried to install a cam cleat using pop rivets. You need to be able to control the force applied by the fastener. If you over- tighten the fastener, you could very easily bind up or even damage the cleat. Rivets don't allow for any control over the applied force (they apply a pre-determined force controlled by when the mandrel breaks off) and stainless rivets apply a fairly high amount of force. Plus, if you ever have to replace the rivet, I think you run a pretty high chance of damaging the cleat when drilling out the rivet head. sm |
| Author: | MVD [ Tue Feb 24, 2015 10:14 pm ] |
Ah, I should have looked at the cam cleat before I asked the question. I was thinking in terms of riveting a base plate to the mast but that's not how the cleat is made. I agree, rivets wouldn't work well in this application. |
