| Depressed/Sunken in but hard area next to trampoline support http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=54664 |
| Author: | bryan062087 [ Fri May 08, 2015 11:06 am ] |
| Post subject: | Depressed/Sunken in but hard area next to trampoline support |
Hi, I'm considering purchasing a Hobie 16. The boat is in good shape; however, the current owner indicates that there is a depressed or sunken in spot next to the trampoline support that comes out of the top of the hull. The spot is not soft. Would this be a deal breaker? I read some through searching on the forum about pylon detachment, but would like some advice on what this spot I've described could be? Thanks. Bryan |
| Author: | mmiller [ Fri May 08, 2015 12:31 pm ] |
| Post subject: | Re: Depressed/Sunken in but hard area next to trampoline sup |
It is possible that the pylon as pushed into the "shoe" down in the keel. That would not be good, but is also repairable. From the forums: Quote: I would recommend you download the Sept/Oct 2009 Hobie Hotline magazine. That issue included an article that specifically discussed the repair procedure for fixing a broken pylon shoe. Quote: http://www.w1dm.com/projects/HOTLINE/Hotline.html Sept/Oct 2009 Hobie Hotline magazine: http://www.w1dm.com/projects/HOTLINE/09-09-10%20HOTLINE.pdf MBounds wrote: 4 inches? That's a lot of motion. I'm not sure if that can be fixed.
The front pylon (that's the proper term), is part of the deck layup, then when the hull/deck are joined, it rests in a "shoe" that bears against the hull. Here's a cross-section of the assembled hull/deck: In your case, it sounds like not only has the shoe become unbonded from the hull, the pylon has become unbonded from the deck. This is a major repair, and not really cost effective on a 40+ year old boat. |
| Author: | bryan062087 [ Sat May 09, 2015 8:51 am ] |
Thanks for the info. Here is a picture of the hulls. Seller says that one of the hulls has a slightly depressed area after the trampoline post. ![]() ![]() Also I noticed it has inspection ports. So perhaps the hulls have been worked on before. |
| Author: | cpnsoo [ Sun May 10, 2015 6:43 pm ] |
Parts boat |
| Author: | msd [ Sun May 10, 2015 9:35 pm ] |
I had that happen to my boat, started in July and I kept sailing through August. It gradually got worse and started to show a bit of cracking towards the end. Was a $800 repair but been sailing it hard for the past 3 seasons with no recurrence. |
| Author: | srm [ Mon May 11, 2015 2:42 am ] |
cpnsoo wrote: Parts boat +1 Hulls are trashed. sm |
