| Mast step link http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=58912 |
| Author: | Zlaprade [ Wed Aug 24, 2016 12:39 am ] |
| Post subject: | Mast step link |
Finally getting around to installing mast step link in early 70s. Hobie 16. I bought the step link kit and directions are horrible. What is "Drill head off press pin in mast step casting and remove with punch and hammer". Anybody have photos of a retro fit of mast that had the hook in the casting? Thanks and i appreciate the help |
| Author: | greensnopro [ Wed Aug 24, 2016 2:10 pm ] |
| Post subject: | Re: Mast step link |
can you post pics of your mast step and maybe the base? that will help. |
| Author: | mmiller [ Wed Aug 24, 2016 4:11 pm ] |
The pin in the mast step casting has to be removed. It is a "Flair" or "Press" pin and the end is being called the head... either end. You need to use a drill (1/4" as I recall) and drill the flair material to thin it or remove it without drilling into the casting. Then use a straight (Pin) punch to push the pin out. You can also use an old drill bit or rod material as a punch. |
