| Mast pulley replacement - how to use rivet caps? http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=59052 |
| Author: | pulssarman [ Thu Sep 08, 2016 4:14 pm ] |
| Post subject: | Mast pulley replacement - how to use rivet caps? |
I have the following parts, but need a sanity check to see if this is the right method to go about this; ![]() Now does the rivet, go into the cap; ![]() And then whole shebang goes into the part (and into the mast), and then riveted into place? Do I need to put any silicone or anything in/under anything? ![]() This is a shot of the bad part; ![]() Thanks!! Or maybe does the cap go in the mast first, then part, then rivet? *shakes head* -Lyle |
| Author: | MBounds [ Thu Sep 08, 2016 7:29 pm ] |
| Post subject: | Re: Mast pulley replacement - how to use rivet caps? |
You've got it right in the first series of photos. But it really doesn't make any significant difference. Rather than silicone, use a bit of Tef-Gel (http://www.westmarine.com/buy/tef-gel-- ... P012222212) to minimize galvanic corrosion between the rivet/rivet cap and the mast. |
| Author: | pulssarman [ Fri Sep 09, 2016 10:34 am ] |
Thanks for verifying my plan of attack! I'll see about getting some of that gel before I start. Thanks! |
