| Rudder Holes http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=59271 |
| Author: | OCNJSLR [ Fri Oct 07, 2016 1:49 pm ] |
| Post subject: | Rudder Holes |
I have old epo rudders and the holes are ovaled. I was thinking about filling the holes with fiberglass chop and resin and then redrilling. Does this sound like a good plan. I am open to suggestions. PS I am a new user. I have been sailing a 16 Hobie for about 3 yrs and I am totally hooked! |
| Author: | srm [ Fri Oct 07, 2016 5:35 pm ] |
| Post subject: | Re: Rudder Holes |
Yep, it is a good plan. I would recommend using an epoxy resin. When you re-drill, try to get the new holes as close to the original position as possible. Also if you can use a drill press, it will help to ensure the axis of the holes remains square to the surface of the blade. sm |
| Author: | OCNJSLR [ Sun Oct 09, 2016 1:34 pm ] |
Thank you for the quick reply. I will use a drill press as you suggest. |
