| New downhaul old boat question http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=63298 |
| Author: | Thiscowboysails [ Wed Jul 25, 2018 1:46 pm ] |
| Post subject: | New downhaul old boat question |
How is the new harken mini block downhaul system mounted to the base of the mast? Sent from my SM-G950U using Tapatalk |
| Author: | srm [ Thu Jul 26, 2018 6:48 am ] |
| Post subject: | Re: New downhaul old boat question |
It uses the same bracket that's mounted to the top of the traveler car. The bracket attaches to the bottom of the luff track using screws and square nuts. Then use a clevis pin to attach the lower block to the bracket. sm |
| Author: | Thiscowboysails [ Fri Jul 27, 2018 3:01 pm ] |
srm wrote: It uses the same bracket that's mounted to the top of the traveler car. The bracket attaches to the bottom of the luff track using screws and square nuts. Then use a clevis pin to attach the lower block to the bracket. Thank you friend sm Sent from my SM-G950U using Tapatalk |
