| H16 halyard captive hardware liberated http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=64408 |
| Author: | yelkenli [ Tue Mar 19, 2019 6:31 pm ] |
| Post subject: | H16 halyard captive hardware liberated |
The pin on my main halyard is gone. I noticed it would come out, though it is supposed to be captive. I will look through my boxes a few more times, and am looking for my old halyard (the missing pin is off a newer halyard). I thought I would post here for a recommendation on a replacement pin. I would hope the pin is a standard diameter and thread, and maybe a standard length. I really do not want to replace my newish halyard. Please help!! Thanks! |
| Author: | srm [ Wed Mar 20, 2019 9:13 am ] |
| Post subject: | Re: H16 halyard captive hardware liberated |
I don’t know the details on the pin (though I would guess it’s 1/4-20 thread, you could easily verify by checking the threads with a screw). Anyway, worst case scenario, I think you could carefully drill out the threads on the shackle and then just use a standard clevis pin with split ring or a quick-pin. That would at least allow you to salvage the halyard if you can’t find the right threaded pin. sm |
| Author: | mmiller [ Wed Mar 20, 2019 3:19 pm ] |
10670000 SHACKLE, HALYARD US$ 12.59 You could take the pin from a new shackle as an option. |
| Author: | yelkenli [ Thu Mar 21, 2019 5:14 pm ] |
I got a new shackle and filed off the pin nubs. Any thoughts on putting the 'captive' back in the pin? Would solder stick to the pin? |
| Author: | mmiller [ Fri Mar 22, 2019 8:47 am ] |
Worth a try! |
| Author: | turbofan [ Sat Mar 23, 2019 1:05 pm ] |
How about a spot of 5200 or JB weld? |
| Author: | A1cnc [ Sun Mar 24, 2019 1:14 pm ] |
The pin is most likely stainless steel. You could try silver solder with a flux. If you know anyone who can tig weld they could easily put a couple dots of weld on the pin. |
