| Replace pulley in front corner casting of H16? http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=67201 |
| Author: | Parkert-2 [ Mon Aug 17, 2020 8:27 am ] |
| Post subject: | Replace pulley in front corner casting of H16? |
Can you replace the pulley in the front corner casting in a Hobie 16? The pulley is integrated in the casting. Looks like a long rivet holds the pulley in place in the aluminum casting. I'm hoping I don't have to replace the whole, really expensive casting just for a plastic pulley.... |
| Author: | AntonLargiader [ Mon Aug 17, 2020 9:21 am ] |
| Post subject: | Re: Replace pulley in front corner casting of H16? |
Yes you can. The sheave and rivet are sold separately and IIRC it's a special long rivet. My casting was mis-drilled (crooked) by the factory so I needed to go in and try to fix it, hence I know about it. |
| Author: | rattle 'n hum [ Wed Aug 19, 2020 4:07 am ] |
From P. 52 of the parts catalog: *FRONT CORNER CASTING JIB TRAVELER SHEAVE SHEAVE 20132031 RIVET 8011251 And P. 64: 8011251 RIVET 3/16 x 1-1/8 PH-AL (Not sure about the PH, but the AL means aluminum.) |
