| Hobie 16 questions http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=67906 |
| Author: | RobLewis [ Wed Feb 17, 2021 4:36 am ] |
| Post subject: | Hobie 16 questions |
I have a new Hobie 16 and have a few qus: 1. The traveller car comes out of the integral track at one end..what is supposed to stop that? The seller said he used a knot on the mainsheet but I think there should be a stop somewhere in the track. 2. I have bought 3 x swivel clam cleats for the main and jib but they have flat bases. Can I reuse the old ones and will self tappers do to secure them? 3. There's a twist toggle on the end of one side stay but not the other...are they that important? 4. What diameter is the tiller rob? Any help appreciated. Cheers |
| Author: | mmiller [ Wed Feb 17, 2021 9:38 am ] |
| Post subject: | Re: Hobie 16 questions |
Use a knot to be sure the car does not smack the corner casting and will keep it in the track, but there is a plate that is supposed to be riveted there. https://s3-us-west-1.amazonaws.com/media.hobie.com/item_attachments/11810011z52.pdf You should be able to re-use the mounting plates. If corrosion is an issue, you can move a bit to one side. This is the mounting plate ![]() Twist toggles take bending load off the anchor pin (a universal joint). Yes, important. Tiller rob? |
