| Sailing up wind http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=6815 |
| Author: | ewbike [ Wed May 23, 2007 5:45 pm ] |
| Post subject: | Sailing up wind |
My Hobie 16 dose not seem to point very well. what could cause this? Mast rake? thanks, Evan |
| Author: | The Dog [ Wed May 23, 2007 6:34 pm ] |
| Post subject: | |
Not enough mast rake or poor sail trim. But "upwind" is relative. Are you trying to keep up upwind with other cats or monohulls? Brian C |
| Author: | ewbike [ Wed May 23, 2007 8:14 pm ] |
| Post subject: | |
well i have instructed sailing on mono hulls for years. so mono hulls. |
| Author: | srm [ Thu May 24, 2007 9:10 am ] |
| Post subject: | |
Upwind your angle will not be as good as most monhulls, but your VMG will blow them away in all but the lightest breeze. sm |
| Author: | John Eaton [ Thu May 24, 2007 9:51 am ] |
| Post subject: | |
Seems like the 14/16 was designed to punch through the surf, reach up and down the beach and fly hulls all the while Sailing these boats upwind, and fast, is an art, experiment with mast rake and weight placement |
| Author: | The Dog [ Thu May 24, 2007 3:27 pm ] |
| Post subject: | |
What srm and John said... Ease off the wind a bit and your cat will more than make up for lost angle with increased boat speed. I had a lot to re-learn when I changed from Mono to Multi (Thistle to H-17). Brian C |
| Author: | ewbike [ Thu May 24, 2007 11:01 pm ] |
| Post subject: | |
thank you all for the advice Evan |
| Author: | bannanahead [ Sat May 26, 2007 7:32 am ] |
| Post subject: | jib traveler |
Where should the jib traveler be set when going up wind? John |
| Author: | mmiller [ Sat May 26, 2007 8:57 am ] |
| Post subject: | Closest to the mast |
Generally towards the mast end of the track. In higher winds the car moves out a bit. The main traveler also can be moved out a bit as the wind speed rises. |
