| color coded jib sheets http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=68163 |
| Author: | greenrobotics [ Sun Apr 11, 2021 8:18 pm ] |
| Post subject: | color coded jib sheets |
Want to use color coded jib sheets tied together. Since a continuous jib sheet is 32 feet, how much longer would the separate sheets need to be so the knot doesn't get pulled into the jam cleats. Not using trapeze. Doing this for the people I take sailing who know nothing. As in" grab the red line and let it out and pull in the green line". Thanks. Harry. |
| Author: | mmiller [ Mon Apr 12, 2021 9:28 am ] |
| Post subject: | Re: color coded jib sheets |
Should work at 32 feet. Tie a knot at the mid-point and give it a try. |
| Author: | greenrobotics [ Mon Apr 12, 2021 1:49 pm ] |
Thanks . I have the previous 1 piece and will try that and let you know. My gut feeling is that the sheet exceeds 16 feet when the jib is set for downwind. |
