| Hull posts loose in Corner Castings http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=68735 |
| Author: | Ramona [ Tue Jul 20, 2021 5:44 am ] |
| Post subject: | Hull posts loose in Corner Castings |
I just installed 2001 hulls on my old 80's hobie 16 frame...I discovered a lateral movement Castings. The hulls when I'm sailing and it seams the hull posts fit loosely in the old corner castings. I read about using tin cans to shim it or epoxying the Castings to the hull posts...I was thinking about using spray foam? Or would the spray foam collapse? |
| Author: | mmiller [ Tue Jul 20, 2021 8:23 am ] |
| Post subject: | Re: Hull posts loose in Corner Castings |
Foam would not be strong enough. There is a huge lever load up in the castings. Epoxy is a good choice or Brass/Aluminum shims. |
