| Tuning http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=9393 |
| Author: | Cayuga [ Wed May 14, 2008 6:09 am ] |
| Post subject: | Tuning |
Novice sailor here that would appreciate an old salt's nod - @ 250# solo, mast rake should be as far back as possible. In order to reduce tiller pull, rudders should also be raked maximum forward. (If raked to far forward, may cause boat to Lee Helm) Rudder trim should be set with + 1/4" trailing edge. Anything else that I should take a look at? |
| Author: | kevfran99 [ Wed May 14, 2008 6:39 am ] |
| Post subject: | |
that your tramp is as tight as possible! |
| Author: | Cayuga [ Wed May 14, 2008 7:44 am ] |
| Post subject: | |
1/4" bow on the rear, 1" each side. |
| Author: | Skipshot [ Wed May 14, 2008 11:40 am ] |
| Post subject: | |
Read a book on tuning - there's just too much for this forum to handle. After reading a book and sailing then come to this forum for tips, where folks are happy to dispense the wisdom of their experience. |
| Author: | mmiller [ Wed May 14, 2008 12:17 pm ] |
| Post subject: | Re: Tuning |
Cayuga wrote: Novice sailor here that would appreciate an old salt's nod -
@ 250# solo, mast rake should be as far back as possible. In order to reduce tiller pull, rudders should also be raked maximum forward. (If raked to far forward, may cause boat to Lee Helm) Rudder trim should be set with + 1/4" trailing edge. Anything else that I should take a look at? Sounds like you have most of it covered. Use the main traveler (let the car move outboard) if the boat flys a hull too easily. Will sail faster trimmed tight and traveled out. Have fun! |
