| Jib traveler car blocks http://www.hobie.com/au/en/forums/viewtopic.php?f=14&t=9693 |
| Author: | mtbiker1961 [ Mon Jun 09, 2008 7:09 pm ] |
| Post subject: | Jib traveler car blocks |
Is there a way to replace just the pulley in the block? Mine are falling apart and I don't want to spend the money to replace them till I decide what I want to upgrade on the system. |
| Author: | vinnynniv [ Mon Jun 09, 2008 7:22 pm ] |
| Post subject: | |
are you talking about the Seaway kind that are on the stand up spring? |
| Author: | mtbiker1961 [ Tue Jun 10, 2008 7:27 am ] |
| Post subject: | |
Yes they are |
| Author: | Tri_X_Troll [ Wed Jun 11, 2008 6:12 am ] |
| Post subject: | |
The old seaways can be had for about $10 each used. |
| Author: | The Dog [ Wed Jun 11, 2008 6:50 am ] |
| Post subject: | |
On those old cars, we drill out the rivet that holds the old sheave. Then we replace it with a Harken 160 ball bearing sheave. We use a 1/4" diameter clevis pin and lock ring or cotter pin to hold it in. Works good. Brian C |
| Author: | vinnynniv [ Wed Jun 11, 2008 12:44 pm ] |
| Post subject: | |
Or like Tri X Troll said, you can have mine for $10 a pop |
| Author: | mtbiker1961 [ Sat Jun 28, 2008 8:57 pm ] |
| Post subject: | |
I bought the harken 160's drilled out the old ones worked like a charm thanks |
| Author: | sunvista [ Mon Jun 30, 2008 6:57 am ] |
| Post subject: | |
Is there any way to replace the sheave at the base of the mast for the jib halyard? I don't think I have ever seen an older boat where this one is not crumbling. |
| Author: | mtbiker1961 [ Mon Jun 30, 2008 7:44 pm ] |
| Post subject: | |
It just so happens that you can do it the same way with the same harken 160 and a 1/4" clevis. thats what I did to mine it worked fine. You will have to remove the rivets but you will have to do that even if you buy a new one the harken is much better |
