| Hobie 17 - main sheet diameter http://www.hobie.com/au/en/forums/viewtopic.php?f=15&t=59667 |
| Author: | mats_c [ Thu Dec 22, 2016 4:44 am ] |
| Post subject: | Hobie 17 - main sheet diameter |
Hi folks, how thick main sheet do you guys recommend? |
| Author: | MBounds [ Thu Dec 22, 2016 12:42 pm ] |
| Post subject: | Re: Hobie 17 - main sheet diameter |
8 mm (5/16") runs through the blocks well and is OK on the hands. The boat originally came with 3/8" (9.5 mm) - easy on the hands, but did not run through the blocks as well. You should use a polyester/Dyneema blend, single braid line. New England Ropes Salsa is the best here in the US, but you might have a hard time obtaining it in Europe. Liros Magic Sheet looks comparable - http://www.liros.com/en/products/produc ... sheet.html. |
| Author: | mats_c [ Thu Dec 29, 2016 6:42 am ] |
Thanks, 8mm Dyneema 14 meters - check...! //Mats |
