| Hobie 14 turbo with Harken furler http://www.hobie.com/au/en/forums/viewtopic.php?f=17&t=12147 |
| Author: | Paewraul [ Fri Apr 03, 2009 8:25 pm ] |
| Post subject: | Hobie 14 turbo with Harken furler |
Just picked up a new parts boat to complete my 14T project, and this boat came with a Harken furler with no attachment points for the bridles (unlike the Hobie version furler). I think I can get away with attaching the bridles to the bottom of the furler with a shackle, but doesn't the 14T bridles have a plate rather than a loop on the "top end" of the bridle. Simple question is that will the stock turbo bridles attach to the Harken furler via a shackle or will I have to have custom bridles made with loops on both ends? If so, how long should the 14T bridles be? Any other advise rather than a shackle to the bottom pin of the furler to attach the bridles? Did any of the stock 14T's come with this set-up? |
| Author: | mmiller [ Fri Apr 03, 2009 9:19 pm ] |
| Post subject: | |
Stock Hobie 14 turbos never had Harken furlers. That is the biggest problem with the Harken. The poor connection of the bridles. It does require a shackle and the connection is not the best. The Hobie furler was designed for bridle wires. |
| Author: | Paewraul [ Sat Apr 04, 2009 6:12 am ] |
| Post subject: | |
Does that mean that this was a conversion? Are the stock hobie furlers prone to breaking? Will the stock bridles work (I don't have any so I need to buy the right ones) |
| Author: | Paewraul [ Sat Apr 04, 2009 6:19 am ] |
| Post subject: | |
Thanks Matt! Never thought of that. I'll be sure to check. |
| Author: | mmiller [ Sat Apr 04, 2009 8:47 am ] |
| Post subject: | |
Stock Hobie furlers are a better choice... not prone to failure. It was designed for the Hobie 18, but used on everything up to the 21 footer. Yes, a 14 with a Harken furler would have been a retrofit kit of some kind. I believe the stock bridles are used when using a Harken furler. |
