| dolphin striker? what for? http://www.hobie.com/au/en/forums/viewtopic.php?f=17&t=2277 |
| Author: | adriano [ Sun Aug 21, 2005 12:39 am ] |
| Post subject: | dolphin striker? what for? |
anyone can explain to me what's a dolphin striker for? |
| Author: | JaimeZX [ Sun Aug 21, 2005 12:01 pm ] |
| Post subject: | |
It stiffens and provides support for the front crossbar. It's required if you're going to sail in high winds and/or plan to trapeze. |
| Author: | Hobie Nick [ Mon Aug 22, 2005 6:09 am ] |
| Post subject: | |
The dolphin stiker on the larger boats (and the 14 if it has one) builds the front crossbar into a truss system giving it greater strength. Just like the trusses used in newr home construction for the roofs. |
| Author: | xanderwess [ Mon Aug 22, 2005 7:48 am ] |
| Post subject: | |
Plus, it pisses off the dolphins. |
| Author: | wakeboardin2k4 [ Mon Aug 22, 2005 9:13 am ] |
| Post subject: | |
where do you get one and how much do they cost? If im 175 lbs will i need one for trapezing? |
| Author: | widerisbetter [ Mon Aug 22, 2005 9:27 am ] |
| Post subject: | Where to find it |
xanderwess wrote: Plus, it pisses off the dolphins.
Look into the parts guide online under parts for the 14 http://static.hobiecat.com/2010_archive/support/pdfs/partguides.pdf Have fun, and stay away from those darn dolphins. |
| Author: | wakeboardin2k4 [ Mon Aug 22, 2005 10:09 am ] |
| Post subject: | |
should my boat already have a dolphin striker |
| Author: | Hobie Nick [ Mon Aug 22, 2005 10:13 am ] |
| Post subject: | |
Not all H14's do. I don't knwo if it is a turbo mod, based on teh year or what. JamieZX will probably know. |
| Author: | MBounds [ Mon Aug 22, 2005 10:16 am ] |
| Post subject: | |
Unless it was originally a "Turbo" model (with a jib), it almost certainly did not have a dolphin striker. If you look at the front underside of the front corner castings, there should be holes drilled through the "web" of the casting. That's where the striker mounts. You can see it in this photo: That's the aftermarket dolphin striker kit. I adapted a Hobie 17 dolphin striker to fit my 14 (rod is the same length, center post only needed about 1 1/2 inches cut off the threaded end) so it looks very much like the 16's dolphin striker and the factory installed striker on the 14. |
| Author: | xanderwess [ Mon Aug 22, 2005 10:17 am ] |
| Post subject: | |
All the newer boats I have seen had them already on (like '84 and newer) but its only like 75 bucks and an hour to put one one. Drill, rivet gun, stainless rivets and a couple of wrenches. I have put 3 or 4 of them on and its not too hard. |
| Author: | xanderwess [ Mon Aug 22, 2005 10:18 am ] |
| Post subject: | |
Matt, do you have a picture readily available of EVERYTHING hobie?? |
| Author: | MBounds [ Mon Aug 22, 2005 10:27 am ] |
| Post subject: | |
No, not really - I just saw this old POS on eBay this AM and thought to myself, "My dolphin striker looks way better than that one." I'm stealing eBay's bandwidth on that photo. They've got plenty to spare. Thought I was pretty resourceful, using the DS off the cracked 17 front crossbar that's been stashed in the garage for about 6 years. Also proved to my wife that it's been worth keeping all these years. ("Honey, no way am I going to throw that away - there are still good parts on it!") |
