| Connection from pontoon to tramp is loose http://www.hobie.com/au/en/forums/viewtopic.php?f=17&t=36082 |
| Author: | jeffcta [ Wed Jun 08, 2011 11:26 am ] |
| Post subject: | Connection from pontoon to tramp is loose |
I just bought a '74 HC and one of the connections between the pontoon and trampoline is a little loose. Is this something I should be concerned about? |
| Author: | sunvista [ Thu Jun 09, 2011 5:54 am ] |
| Post subject: | Re: Connection from pontoon to tramp is loose |
Its not really dangerous but your boat's rigidity affects its performance. The pylon bolts are shoulder bolts and only keep the frame and hulls from separating. You can't really tighten that connection. As old as your boat is all four are probably somewhat loose. You need to shim between the pylons and the corner castings. I used some aluminum roofers flashing I got at Lowes. |
