| jib halyard http://www.hobie.com/au/en/forums/viewtopic.php?f=17&t=48743 |
| Author: | jotag [ Fri Aug 02, 2013 7:23 am ] |
| Post subject: | jib halyard |
Could someone give me an idea about how place a jib halyard in my H14T. I dont want to remove the mast each time. Thanks. |
| Author: | srm [ Fri Aug 02, 2013 9:50 am ] |
| Post subject: | Re: jib halyard |
It would be a lot of work. You would basically have to create a system that operates like the H18 system. This would include having the jib modified to install a zipper along the luff sleeve, a cleat added to the jib to set the jib halyard tension, and the forestay would need to be modified to add a halyard sheave. This would be pretty expensive. You would be a lot better off just buying a "snorkel" jib cover. They are hoisted using the main halyard and are installed over the jib when it's furled. sm |
| Author: | jotag [ Thu Aug 08, 2013 6:32 am ] |
Thanks. I will try. |
| Author: | ujm9 [ Fri Jul 03, 2015 11:52 am ] |
This is what I did to my H14: I took the sidestays from a H16 and cut about 50cm off of them and then recrimped them. They go from each bow up to a H16 halyard block. The jib can still be furled without the forestay getting twisted in the jib.
