| H14 Hull spacing dimensions for trailer needed http://www.hobie.com/au/en/forums/viewtopic.php?f=17&t=54498 |
| Author: | thehazards [ Mon Apr 20, 2015 5:13 am ] |
| Post subject: | H14 Hull spacing dimensions for trailer needed |
My H14 is lying on lake Soustons in SW France and so I cant measure it up for a flat bed road trailer that I am adapting to carry it by fitting 2 cross bars of about 8 feet each to the front and rear. My concern is that the wheel mudguards wont fit between the centre of hulls and I'll have to raise the bars or the supports. I also need to know where to position the supports So, could someone please measure: The distance between the bottom points/Vs of the hulls (ie V - V) at: a) the centre of the boat b) under the front tramp cross bar c) under the rear tramp cross bar Thanks in anticipation. Huw |
| Author: | flatlander [ Mon Apr 20, 2015 6:21 pm ] |
| Post subject: | Re: H14 Hull spacing dimensions for trailer needed |
It's approximately 80" at the front crossbar 82" at the rear crossbar I have 60" outside to outside of wheel fenders of this trailer with about 5-6" clear note these were taken off my '84 project boat that has four H16 masts on the trailer, below the boat. I had to set the measuring tape on the ground and eyeball it. Viva la 14 !!! |
| Author: | thehazards [ Fri Apr 24, 2015 7:18 am ] |
flatlander wrote: It's approximately 80" at the front crossbar 82" at the rear crossbar I have 60" outside to outside of wheel fenders of this trailer with about 5-6" clear note these were taken off my '84 project boat that has four H16 masts on the trailer, below the boat. I had to set the measuring tape on the ground and eyeball it. Viva la 14 !!! Thanks flatlander that's useful |
