It is currently Tue Jan 21, 2020 10:41 am
PostPosted: Fri Sep 11, 2015 7:27 am
I just purchased a 14' Hobie Cat that was the foundation of a tri maran patio boat. I'm going to modify it extensively,
description of what I see"
I find the rear cross member that runs left/right between the hulls to be straight/flat
while the front cross member is heavily bowed.
what I'd like to do:
I'd like to replace the curved front piece (and castings) with another 'rear cross member and castings'
this would give me a flat foundation to build on
here are my questions:
1 - Is this a simple bolt / rivet operation? I'll be fastening steel tubing to this base structure then building from there.
2 - are the parts I'm talking about the same between the 14 and 16' boats?
if the 16 footer's cross members are simply longer I can cut it.
3 - are there some models of these boats that are Not interchangeable while others are (racing or Turbo, etc.)
thank you for your knowledge and typing. I hope to hear this project of mine is a Piece O Cake, then I'll start looking for used parts. I'm in northern California and a few hundred mile drive is just my style. Gary in Red Bluff - south of Redding
PostPosted: Fri Sep 11, 2015 8:44 am
Hobie Tech / Moderator
All of the parts are shown in the guide, you'll see when a part is the same or different between them since both models are in the same guide - link: http://static.hobiecat.com/digital_assets/14-16Parts2016.pdf
Jacques Bernier
http://www.hobiecat.com/
PostPosted: Fri Sep 11, 2015 9:53 am
thank you Jacques, that's great!
PostPosted: Fri Sep 11, 2015 3:20 pm
Wow. Wouldn't be easier to find an intact 14?
Actually, I know where there are a 14 and a 16 stacked on a trailer in a guy's backyard that he tried unsuccessfully to sell a few years ago. He'd probably entertain an offer.
Yet another Bob!
PostPosted: Fri Sep 11, 2015 7:47 pm
dorienc, thanks. I've looked at the boat quite a bit and figure I can rig up something without buying parts. These are pretty cool little boats, though I'm sure mine looks nothing like yours. I'm taking it out tomorrow for the first time and will see how it does.
Right now it only has a battery and a 12 volt trolling motor. It will have solar panels and a battery and charge controller. It's taking the place of my 16 foot canoe with a kayak outrigger. By the time I had it all loaded up with ice chests and camping equipment it was just too low in the water. So 'enter' the hobie cat.
PostPosted: Sat Sep 12, 2015 8:26 am
You might find this video interesting if that is similar to what you're planning to do:
For what it's worth, I have an '84 turbo and while it is in quite good shape, getting anything apart can often be a big pain. Parts for these boats are readily available though.
PostPosted: Sat Sep 12, 2015 6:54 pm
Dave, I don't see a link to a video, can you post it again? thanks
PostPosted: Sat Sep 12, 2015 6:58 pm
Dave, it took a second but the video showed up, thanks!
