| Hobie 14 Turbo shroud length? http://www.hobie.com/au/en/forums/viewtopic.php?f=17&t=63022 |
| Author: | Cat toy [ Sat Jun 23, 2018 9:13 pm ] |
| Post subject: | Hobie 14 Turbo shroud length? |
I have a pre-1982 Hobie 14 that I just bought earlier this year. Included were most of the parts needed to convert it to a turbo. Here’s my question: I’ve seen that there is an upgrade kit that would usually need to be ordered in addition to a turbo kit if your boat is older than 1982, and that upgrade kit mentions updated shroud lengths. A few weeks ago, I ordered new standard Hobie 14 shrouds (part #10792100). Are these correct for a Turbo as well? Or do I need to order yet another set of shrouds that are turbo-specific? 1970 Hobie 14 (soon to be Turbo) |
| Author: | srm [ Mon Jun 25, 2018 9:07 am ] |
| Post subject: | Re: Hobie 14 Turbo shroud length? |
The simple answer to your question is as long as the forestay reaches, then the new shrouds are OK. The new shrouds are likely a little bit shorter than the old ones, but you can usually make up any difference by using the shroud adjusters. If needed, you can get a few more inches of length by switching from 7-hole to 10-hole adjusters on the side stays or by adding a second adjuster to the forestay/bridle. sm |
