| Need help on identifing a Hobie 14, 14turbo or hobie 16 http://www.hobie.com/au/en/forums/viewtopic.php?f=17&t=6538 |
| Author: | CharlieD [ Sun Apr 15, 2007 12:00 am ] |
| Post subject: | Need help on identifing a Hobie 14, 14turbo or hobie 16 |
Hello, i have recently come a cross a Hobie Cat and cannot figure out which one of the three models it is, the hull is 14 feet in length, and is what you can say 'half rigged' as a turbo, but at the same time, is missing several components that are listed in the Hobie catalogs "Turbo Kit," I can get the VIN, but i know the production year is 1983. The previous owner is certain it is a Hobie 16, but it has a roller-furling jib and the catalog beg makes me think its a H14 Turbo. Help on my little problem would be greatly appreciated considering i am in the process of purchasing new hardware, lines and sheets etc. P.S.- I took it out in the water last year and it seemed to be riding low in the water, and i cannot find cheap way to weigh it and i was wondering what the water line should be like with myself, at 160#. -Charlie |
| Author: | MBounds [ Sun Apr 15, 2007 4:54 am ] |
| Post subject: | |
The easiest way to distinguish between a 14 and a 16 is how the shrouds attach: 14's shrouds attach to the sidebar 16's shrouds attach to the hull If a 14 has never been "Turbo'ed" it will not have a dolphin striker. The cheapest way to weigh the boat is to take two bathroom scales, put them on two 18" squares of at least 1/2" plywood and then put one under each hull at the shrouds on level ground. Put mast, sails, battens, rudders, etc. on the trampoline - move them forward or back until the boat balances on the scales. Target weight for the 14: 240 lbs; for the 16: 320 lbs. To get the most accurate weight, calibrate the scales with barbell weights before you put the boat on them. Read the scales and add. Should be accurate +/- 2 lbs if you've calibrated. From the sounds of it, you've got a 14 Turbo. |
| Author: | CharlieD [ Sun Apr 15, 2007 12:22 pm ] |
| Post subject: | Thanks |
Thank you for the help itll be very helpful |
| Author: | gree2056 [ Sun Apr 15, 2007 6:04 pm ] |
| Post subject: | |
The 14 sits very low in the water, there really isn't a water line, it all depends on where you are setting and what the wind is doing. |
| Author: | CBFryman [ Sat Apr 21, 2007 2:36 pm ] |
| Post subject: | |
I'm not a hobie expert but the H16 has a forstay and a deperate jib connection. My H14 uses the Jib as the forestay. |
