| Racing upwind http://www.hobie.com/au/en/forums/viewtopic.php?f=17&t=9933 |
| Author: | Jbarth13 [ Sat Jul 05, 2008 9:14 am ] |
| Post subject: | Racing upwind |
It is common knowledge that cats are fastest off the wind. Because of this, I would imagine that bearing off slightly is best when going for the first mark. My question is, how far should I bear off? Does this depend on wind conditions? I'm frustrated because I can never seem to find the balance between speed and upwind progress that would allow me to win the beat. By the way, I'm sailing a Turbo. Thanks Jon |
| Author: | mmiller [ Sun Jul 06, 2008 9:46 am ] |
| Post subject: | |
Quote: In the past, I've always just sheeted in as far as I could and pointed as high as the conditions would allow. The boat always felt constrained and held back
Yes, bearing off for speed and then coming back up as far as possible is the trick. You can not point high sheeted tight and pinching. You have to have some boat speed. Otherwise the boat crabs sideways more. Plus the sheeting is likely stalling the boat speed.
Tell tails in the upper third of the sail really help to tune the sheeting. It is easy to over sheet. You need to pay attention to the air flow in that area. Tails at the leach should flow aft and hook behind the sail alternately. |
