| Super Glue Repair Patch http://www.hobie.com/au/en/forums/viewtopic.php?f=20&t=10008 |
| Author: | Whip [ Fri Jul 11, 2008 1:25 pm ] |
| Post subject: | Super Glue Repair Patch |
I found this quick patch sheet material (Glass reinforced polyester ) and purchased it to give it a try. All I can say is Wow. Great stuff!!! Sold with Super Glue branding as "Permanant Patch" Permanent Adhesive Patch Anchot-Tite Patch is a very easy-to-use UV or sunlight activated repair patch. It is fiberglass-reinforced and creates long-lasting repairs. Can be cut to size and molded to a desired application shape. Will not rot or rust and can be drilled or tapped after cured. Accepts paint in 1 hour and can be sanded to a smooth finish. Click for PD sheetWorks best on:• Water tanks • Flashing air conditioning units • Personal watercraft • Engine Parts • Metal • Concrete • Roofs • PVC pipes • Boats • Fiberglass • Wood |
