| Water in mast http://www.hobie.com/au/en/forums/viewtopic.php?f=20&t=1170 |
| Author: | jes9613 [ Tue Sep 14, 2004 10:12 am ] |
| Post subject: | Water in mast |
Hey Guys, Installed a comptip this spring and went to take the mast down for the year when I noticed plenty of water in the mast below the comptip. Just wondering, is it easier to remove the base, drain, replace the base, then seal the mast or drill a hole, drain, seal the hole, seal the rest of the mast? Thanks, John |
| Author: | mmiller [ Wed Sep 15, 2004 8:43 am ] |
| Post subject: | Water in the metal section... |
Did you install the plug below the tip? Epoxy the tip in place? Possibly the water is coming in elsewhere, but if the plug was not installed, drill a hole below the joint to drain. Pressurize and check for leaks elsewhere. You can inject a 2 part (floatation) foam into the mast below the tip. This would be a short squirt of foam to create a 1 foot long plug right at the connection. Tip the mast head down and squirt the foam in. Plug the hole with a finger while the foam expands... so it doesn't squirt back at you! |
| Author: | jes9613 [ Wed Sep 15, 2004 11:54 am ] |
| Post subject: | |
Plug installed, tip epoxy set, water is in the lower part of the mast. I'm thinking, remove the base, find the leak, and re-rivet the base back on. Any thoughts? John |
| Author: | mmiller [ Wed Sep 15, 2004 11:57 am ] |
| Post subject: | Thoughts |
Drill out one base rivet and inject air pressure. Soap around the whole lower mast looking for bubbles that would identify a leak. It is likely that the upper plug slipped out of place or is leaking under pressure of a capsize (turtled?). |
