| Help with NON-Comptip mast head leak and sealing http://www.hobie.com/au/en/forums/viewtopic.php?f=20&t=22632 |
| Author: | GAhobie [ Mon Mar 29, 2010 5:39 am ] |
| Post subject: | Help with NON-Comptip mast head leak and sealing |
I am working to get my mast sealed up as it caused me issues last season. I used a shop vac to put some presure inside the mast and discovered that the leak was coming from the top, or head of the mast. So I drilled out the rivets and pulled the head. What I found was a loose piece of silicon and under that a foam block. How should I go about resealing this old mast top before I put the head back on? |
| Author: | Nevek [ Mon Mar 29, 2010 6:39 am ] |
| Post subject: | Re: Help with NON-Comptip mast head leak and sealing |
I cleaned the area as best as I could with a razor blade/file, then I filled the it with some foam (dont use greatstuff, I bought my stuff from west marine). After I put a little foam in there the little metal plate fit nicely sitting on top of the foam and I sealed it in with some 3M 5200. Reattach the mast head with 2x 3/16 rivets and youre good to go! |
