| Fill hole in frame? http://www.hobie.com/au/en/forums/viewtopic.php?f=20&t=28882 |
| Author: | Jman6631 [ Wed Aug 04, 2010 10:40 am ] |
| Post subject: | Fill hole in frame? |
I'm thinking about making some changes to my jib setup and may remove a fitting or two. What is the best way to fill the holes in the extruded frames? Epoxy? Rivets with top hats? Both? Thanks in advance for anything! |
| Author: | MBounds [ Wed Aug 04, 2010 11:58 am ] |
| Post subject: | Re: Fill hole in frame? |
Most people just leave the holes. |
| Author: | srm [ Wed Aug 04, 2010 1:29 pm ] |
I've used rivets to fill the holes on my 17 mast. When I first got it, I removed the stock downhaul system and upgraded, so I needed to fill the holes to keep the mast sealed. If you do use rivets, I would definintely recommend using aluminum. They pop real easy and won't corrode the aluminum extrusion like stainless will. No need for top-hats since you're not trying to keep the crossbar sealed. sm |
| Author: | Jman6631 [ Wed Aug 04, 2010 4:32 pm ] |
Ok good enough, thanks guys! |
