| Drying out a comp-tip http://www.hobie.com/au/en/forums/viewtopic.php?f=20&t=37211 |
| Author: | poolemarkw [ Mon Aug 01, 2011 8:10 pm ] |
| Post subject: | Drying out a comp-tip |
I just pulled a comp-tip out of mast to move to a different base and the foam inside the comp-tip is wet. I have no idea how deep the wetness goes. So...what's the best thing to do? I've heard of using gasoline to melt foam before. Should I do this to remove all the foam and then replace it with two-part foam? thanks, Mark |
| Author: | MBounds [ Tue Aug 02, 2011 4:36 am ] |
| Post subject: | Re: Drying out a comp-tip |
poolemarkw wrote: So...what's the best thing to do? I've heard of using gasoline to melt foam before. Should I do this to remove all the foam and then replace it with two-part foam? Just leave it out in the sun for a few days. Removing the foam with gasoline is extraordinarily dangerous. If you want to remove the foam, then use mechanical, not chemical means. |
| Author: | gary eudy [ Tue Aug 02, 2011 8:52 am ] |
how about a small fire |
