| Removing old sealant on thru-fittings, mast and pylons? http://www.hobie.com/au/en/forums/viewtopic.php?f=20&t=44753 |
| Author: | jimrude [ Wed Aug 29, 2012 7:49 pm ] |
| Post subject: | Removing old sealant on thru-fittings, mast and pylons? |
With a lot of help from forumites here, we just bought a 1981 Hobie 16 in (relatively) good condition. However, basically ALL of the boat is original - rigging, etc. The previous original owner abundantly coated most of the mast, as well as the thru-hull fittings, with a greyish sealant, that is now ugly and rubbery. The Hobie dealer recommended removing this with acetone and a putty knife, and then re-sealing with clear 3M 5200. Thoughts or suggestions? Thanks for all your help! |
| Author: | srm [ Thu Aug 30, 2012 2:44 am ] |
| Post subject: | Re: Removing old sealant on thru-fittings, mast and pylons? |
5200 is a permanent sealant/adhesive. I would not use it on any parts you plan to or may have to remove in the future. Just use a quality marine silicone caulk and you will be fine. sm |
