| Hobie 16 built in early 70's with grunions pulling out http://www.hobie.com/au/en/forums/viewtopic.php?f=20&t=52219 |
| Author: | umhau [ Sat Jul 19, 2014 9:00 am ] |
| Post subject: | Hobie 16 built in early 70's with grunions pulling out |
Hi- Sailing in high wind, the screws on the lower grunion of my old hobie 16 pulled out, cracking the transom in the process. Can anyone advise me on how to fix this? I do not see an aluminum block in the transom as described in later models. ( my sail # is 1957). Do I cut a hole in the deck and put in some kind of a block to put the screws into? Is this fixable? How can I upload a photo of this damage? THANKS! john |
| Author: | Jbernier [ Mon Jul 21, 2014 8:24 am ] |
| Post subject: | Re: Hobie 16 built in early 70's with grunions pulling out |
here are instructions for uploading photos http://www.hobiecat.com/forums/viewtopic.php?f=18&t=8574 They're called Gudgeons - I believe a Grunion is a type of fish |
| Author: | rattle 'n hum [ Mon Jul 21, 2014 10:35 am ] |
We should be able to tell more with pictures, but..... If your transom damage isn't structural, and... If your old screws were #12 (stock, at least for many years), and... If by "pulled out" you mean stripped, not sheared, and.... If you can get the screws out where holes were damaged, then... The easiest repair is to tap the holes up a size to 1/4 inch and use SS screws from your local hardware store. Unless the transom is ripped open (a different repair entirely), you should not be able to see the aluminum plate. Normally one would think it's best to replace all the screws, not just the stripped ones, BUT beware! On a boat that old, the screws that didn't strip are likely fused to the plate from corrosion. If you try unscrewing one and it won't budge with reasonable force, stop and just let it go. Otherwise, you might shear it and have a much worse problem. If you can get all the screws out, now is the time to repair the transom, if necessary, and reseal the gudgeons so they don't leak.....maybe the drain plug housing too! Also, put a little lanacote or such on the gudgeon screws to inhibit corrosion. Good luck! |
| Author: | abbman [ Mon Jul 21, 2014 1:32 pm ] |
This exact thing happened to my 86' while sailing off Myrtle beach. It did not crack the transom, however. A hobie is rather difficult to sail with one of the rudders near horizontal. I had to accidentally gybe all the way back to the beach. It wasn't fun at all. Several of the ss screws broke off inside the hull. I tried drilling out the screws, but that proved to be near impossible. EZ outs didn't work either. If you try to drill them out, invest in high quality cobalt left handed drill bits. That way if they grab the screw things are moving in the right direction. I then sought the advice of others on this forum and several close friends. I ultimately came to two possibilities: It was a given that I was going to upgrade to the one-piece gudgeons, then... 1. Cut ports in the sterns, re-drill the transom, and thru-bolt. 2. Cut out the aluminum plate, glue in a new plate, fiberglass over the new plate, drill, tap new holes, and install the new gudgeons. I went with option 2. I just did't want to put ports in a perfectly solid hull. I did this repair in the spring and I've been sailing hard all summer with no issues. To be honest, the transom is probably more beefed up than it was from the factory. It sounds like a lot of work, and it was to an extent, but I am happy that I didn't have to through bolt and worry about potential leaks in the future. Plus, it just seemed like it would be really hard to work inside of the hull from a 4 inch opening. So, here is the run-down of what I did. If you want more detail or would like to know where I got supplies, shoot me a pm. 1. Use a dremel to begin removing the gel, glass, and plywood from the back of the transom. Use the screw holes as an initial guide and then work your way outwards until you have the whole plate exposed. You will cut close to the outside of the hull. 2. Remove the plate. On an old boat there is likely going to be some corrosion. It will likely come out very easily. If not, take your time and try not to crack the inside glass. It is really thin. 3. Clean everything up nicely. 4. Glue in the new plate with 2 part epoxy thickened with cabosil 5. Let the glue set for at least 24 hours. 6. Fill in gaps with thickened epoxy mixed with Q cells to aid in sanding. 7. Begin to taper out the transom for new glass to adhere with a side-angle grinder. 8. Begin to lay filets of glass, starting small and building the transom back up. 9. When you feel like you've built them back, sand and fair them smooth. 10. Re-gel the transom 11. Drill new holes using the new gudgeons as a template 12. Tap the holes 13. Install the new gudgeons 14. Sail it like you stole it. I hope this helps some. I was really intimidated by this repair and it took a couple of years before I felt like I knew enough about what I was doing. I had never done a major repair before on the boat or laid fiberglass. I simply didn't have the funds to take it to a boat shop, so I had to do it on my own. To be honest though, it wasn't nearly as difficult a repair as I thought it would be. If you get in there though and start to see real structural problems, you may want to seek the advice and/or repair from a pro. Here are some pics of my hulls and the process. I stopped taking photos after laying the glass. I think I just got a little antsy to get to the water. I ended up going with regular old white gel coat. It's an old junkyard boat so I didn't really care about the cosmetics. To be honest though, it looks kind of cool with the white transoms I think. http://s1319.photobucket.com/user/jsaut ... t=2&page=1 Pics would be helpful. |
