| Hobie 21 taper pins http://www.hobie.com/au/en/forums/viewtopic.php?f=20&t=629 |
| Author: | John Stuart [ Sun Feb 01, 2004 12:15 pm ] |
| Post subject: | Hobie 21 taper pins |
I have a problem with a hobie 21. The holes in the crossbeams, through which the taper pins pass, have become large and corroded. The taper pins are rendered ineffective, which allows a lot of play between the hulls and the crossbeams. Any suggestions on a good fix for this will be much appreciated |
| Author: | sunjammers [ Mon Feb 02, 2004 10:09 pm ] |
| Post subject: | |
If you can get us some pictures I will try to help you out. What year is the boat? Thanks, Brad Stephens www.sunjammers.com<------New Site! Authorized Hobie/Vanguard Dealer Division 15 Chairman Panama City Beach, FL [email protected] 850-235-2281 |
| Author: | Hammond [ Mon Jul 18, 2005 12:48 am ] |
| Post subject: | |
I also had this issue, good old wear and tear. Check the inside diameter of the holes and have a machine shop turn some pins for you. Make sure you allow enough threads to tighten the taper pins. |
| Author: | Beachboy [ Mon Jul 25, 2005 10:05 am ] |
| Post subject: | |
I have a '88 21SE and am familiar with the pins. I think having those pins made, especially from stainless would cost $500+. I would suggest cleaning out the holes and welding them back smaller then re-bore to the correct size. You will probably have to remove the sleeves to avoid heat damage but they are easy to rivet back on if you remove them carefully. |
