| Hole in Mast http://www.hobie.com/au/en/forums/viewtopic.php?f=20&t=64636 |
| Author: | freeheel100 [ Wed May 01, 2019 7:48 am ] |
| Post subject: | Hole in Mast |
I just discovered a pencil-size hole in the mast of my SE-21. I store it inside during the winter, so I'm not sure what caused it. There appears to be an orange matter inside the hole. I have a couple other small pits. Does anyone have any suggestions to repair this? |
| Author: | Bill 404 [ Wed May 01, 2019 7:57 am ] |
| Post subject: | Re: Hole in Mast |
I buddy who builds helicopters recommends Devcon Aluminum Putty. He gave me a 1lb. can of it that I used on an old 16 mast. It worked perfect...now 10 years on... |
| Author: | freeheel100 [ Wed May 01, 2019 10:30 am ] |
Thanks! |
| Author: | srm [ Wed May 01, 2019 11:50 am ] |
Assuming what you are describing is a hole caused by corrosion, I would guess that the damaged area of the base aluminum extends significantly farther than the extent of the hole itself. I would see if you can peek inside the mast somehow or poke around the hole with a screwdriver to see if more material breaks away. I would also look around all stainless fittings (possibly remove and look under them) to see if there are more corroded areas. sm |
| Author: | freeheel100 [ Wed May 01, 2019 4:40 pm ] |
Great advice, thank you. |
