The left Bow Plate on my 1974 Hobie 14 has come loose. It appears that the bolts/screws that hold one of the sides of the Bow Plate have been ripped out of their attachment holes/threads. When attempting to screw them down tightly, they do not grab any threads. I am looking for suggestions on how this might be repaired.
A thought is to remove the screws from the "working" side (to eliminate pressure on the "to be repaired" side), then fill the holes with epoxy and then inserting the original screws, allowing this to set up, and then reattaching the screws in the "working" side. Not sure if this is a good idea.
I would appreciate feedback and other ideas.
Thank you
