| How can I make the metal tramp frame look good again? http://www.hobie.com/au/en/forums/viewtopic.php?f=20&t=7098 |
| Author: | Sharkdog [ Mon Jun 25, 2007 11:44 am ] |
| Post subject: | How can I make the metal tramp frame look good again? |
My hobie 14tj is in pretty good shape but I wouldn't mind making her look a little prettier. The tramp frame was originally that black andoized metal they talked about in the brochures back in the day. Over the years it has faded to gun metal grey and been scratched, etc. Can I just paint this black again? What kind of paint would I use? Heck, can I paint the mast and boom while I'm at it? |
| Author: | sailor33133 [ Thu Jun 28, 2007 4:24 pm ] |
| Post subject: | |
two part polyurothane paint is strongest followed by one part poly paint ruff/scuff the black anodised finish with wet sand paper 400 grit that will also clean off any oil wax or other stuff on there no need to sand thru the black finish just clean and tooth the surface clean smooth surface prep is the big deal to get a good job spraying will give the best result, then a roller or pads [sponge] avoid old style brushes and poly, it tends to show brush marks as it fast drys before the brush marks flow out sure paint what ever you want |
| Author: | sunjammers [ Thu Jun 28, 2007 7:40 pm ] |
| Post subject: | |
I've never seen a paint job last on cross bars, if its the side rails all carpet kit |
