| Single Handed trapeeze http://www.hobie.com/au/en/forums/viewtopic.php?f=23&t=11201 |
| Author: | sail.fast24 [ Thu Nov 13, 2008 9:17 pm ] |
| Post subject: | Single Handed trapeeze |
Hey I have a question for those who single hand trapeeze. Do you guys have tiller extentions? Would it work to just stand way back so I can reach the stock tiller? I hate the idea of spending big bucks on a longer tiller if I'm only going to use it very little. Would standing wayyyy back put to much stress on the mast? Another question... Does any one have ideas for possible double tillers? The problem would be that the leeward tiller would fall into the water. Any thoughts or ideas would be appreciated! Thanks |
| Author: | iresq [ Fri Nov 14, 2008 11:58 am ] |
| Post subject: | |
I don't trap from my getaway but have solo on 16. I am not sure the stock tiller extension is long enough. There was a mod posted on this site were someone did rig up double tillers. They used U clips (like the kind that would hold brooms) mounted to the rudder connection bar. |
| Author: | IndyWave [ Fri Nov 14, 2008 3:03 pm ] |
| Post subject: | |
Check the pictures of what I rigged up for my Wave. http://www.hobiecat.com/community/viewtopic.php?t=9247 Maybe it will give you some ideas. |
| Author: | Roy [ Fri Nov 14, 2008 7:12 pm ] |
| Post subject: | |
I went out and bought a commercial grade paint stick extender, then just make up the end to fit on the boat, they come in different lengths and with just a twist of the wrist you can make it longer or shorter. and for a about 20 bucks its cheap. |
| Author: | crobiecat [ Fri Nov 14, 2008 9:38 pm ] |
| Post subject: | Re: Single Handed trapeeze |
sail.fast24 wrote: Hey I have a question for those who single hand trapeeze. Do you guys have tiller extentions? Would it work to just stand way back so I can reach the stock tiller? I hate the idea of spending big bucks on a longer tiller if I'm only going to use it very little. Would standing wayyyy back put to much stress on the mast?
Thanks I replaced the original tiller with a FX03 Arriba HotStick almost immediately after I got my Getaway, as I found the stock tiller too flexible for my taste. The FX03 about 1 foot longer than the stock tiller and works fine for trapezing. |
| Author: | GPratt [ Thu Nov 20, 2008 3:20 pm ] |
| Post subject: | |
SailFast, Check out my earlier post: http://www.hobiecat.com/community/viewtopic.php?t=10926 I used a telescoping aluminum paint roller extension. Works great. I actually installed one on each side with clips to hold the one I wasn't using. It didn't really make it any easier so I took one off and am back to a single. Gordon |
