| DRILLING HOLES IN THE MAIN BEAM http://www.hobie.com/au/en/forums/viewtopic.php?f=23&t=2009 |
| Author: | NORM HARGROVE [ Wed Jul 06, 2005 6:09 am ] |
| Post subject: | DRILLING HOLES IN THE MAIN BEAM |
I WANT TO ATTACH MY RIGHTING POLE TO THE FRONT MAIN BEAM. CAN I DRILL A HOLE THRU THE ENTIRE BEAM,FRONT TO REAR, WITH S.S. BOLTS,TO ATTACH THE SUPPORT BRACKET, WITHOUT DAMAGING ANYTHING (INNER STRUCTURE)??? |
| Author: | mmiller [ Fri Jul 08, 2005 10:29 am ] |
| Post subject: | Forward beam |
The beams are hollow. We do the same for mounting the seats. No problem. |
| Author: | zhopper [ Mon Feb 06, 2006 7:53 am ] |
| Post subject: | |
Matt, Rick White's righting pole uses rivets or screws to attach a bracket to the center of the beam. Seems a little overkill to through bolt it. The beams look alot bigger than H16's. Have you seen any problems with mounting these poles (start of cracks etc) I weigh 155 and have wings on the boat. Water bag just doesn't cut it. |
