| comptip problems. http://www.hobie.com/au/en/forums/viewtopic.php?f=23&t=23024 |
| Author: | Desmond Becker [ Tue Apr 06, 2010 5:36 pm ] |
| Post subject: | comptip problems. |
Ok,had my getaway since 2003,i have noticed my comptip seems to be pulling further into the aluminium section,yes,it is glued but moving dramatically causing the rig to be a little looser the usual when it is in it's usual position.I can't really tension it much more,so will a new comptip eventually be required? Tasmania's only getaway sailor. |
| Author: | mmiller [ Wed Apr 07, 2010 10:05 am ] |
| Post subject: | Re: comptip problems. |
The glue isn't holding. Re-seat with new epoxy and add a few (4 or more) rivets. That should lock it in place better. |
| Author: | gmozavala [ Thu Apr 08, 2010 12:53 pm ] |
I have a friend who is having the same problem. Where should I put the rivets? I was thinking about an inch below the joint and evenly distributed in the perimeter of the mast.... Does that seem ok? thanks, Guillermo |
| Author: | mmiller [ Thu Apr 08, 2010 1:48 pm ] |
Makes sense to me. |
| Author: | Desmond Becker [ Sat Apr 10, 2010 3:38 pm ] |
So it can be drilled,phew!Now I just have to get the sections apart!! Tasmania's only getaway sailor. |
