| ezlock rudders... too tight... lube? http://www.hobie.com/au/en/forums/viewtopic.php?f=23&t=49220 |
| Author: | iowadivers [ Sun Sep 08, 2013 5:24 pm ] |
| Post subject: | ezlock rudders... too tight... lube? |
just bought a getaway that has been sitting for a few years... the rudder system is in great shape however one side seems to have a lot of resistance moving rudder up and down... is it possible to lubricate the moving parts or should I just loosen the bolts off a bit? what is the suggested practice to make sure the rudder system transitions smoothly from the up/locked to down position? Matt |
| Author: | Craig9r [ Mon Sep 09, 2013 8:11 am ] |
| Post subject: | Re: ezlock rudders... too tight... lube? |
I had a problem with my rudders being too loose, they kept popping up when I gained speed. I ended up tightening the bolt on each rudder 1 full turn. There is a ez lock PDF file I found searching the web that explains it. I would imagine 1 turn counterclockwise would loosen them enough. You would have to test it out. |
