| Mast Step Ball Lubricant http://www.hobie.com/au/en/forums/viewtopic.php?f=23&t=54269 |
| Author: | Diver_fcd [ Sun Mar 29, 2015 12:54 pm ] |
| Post subject: | Mast Step Ball Lubricant |
On days when the wind is variable and lite, my mast tends to swivel on the ball a lot. When it does, it tends to make a loud squeaking noise. Is there some sort of lubricant I should be using? Thanks! |
| Author: | wxup [ Sun Mar 29, 2015 5:11 pm ] |
| Post subject: | Re: Mast Step Ball Lubricant |
MCLUBE Sailkote Dry Lubricant. Available at West Marine. I use it to lube everything on the boat. Works great. |
| Author: | srm [ Tue Mar 31, 2015 2:48 am ] |
Small dab of automotive bearing grease up inside the socket of the mast base. sm |
| Author: | mickjf [ Wed Apr 01, 2015 5:23 pm ] |
Yeah I just throw some automotive grease onto the ball but need to do it each time I rig the boat. Would this spray negate the need to do it each time? Secondly, I only had this problem when I replaced the the ball and mast base. First time it happened, it actually ground away some of the ball as well, but we had been sailing for a couple of hours before it started, so I am at a loss as to what cause it. Had it been sand or similar, it should have started making the noise straight away. Weird. |
| Author: | powerj [ Wed May 13, 2015 4:02 pm ] |
McLube is the only war to go!! Been using it for 30 years. It can also make cleats, blocks and pulleys like new. Rudder locks return to normal. |
| Author: | Tom Kirkman [ Wed May 13, 2015 4:50 pm ] |
Go the to local discount store and buy a bag of practice "wiffle" golf balls. Cut one in half, exactly. Place this in the mast step indention and forego lubricants forever. It will fit perfectly, provide a slip fit and won't tend to come out even when the mast is down. |
