| Getaway hull play http://www.hobie.com/au/en/forums/viewtopic.php?f=23&t=60219 |
| Author: | chincoteaguesailer [ Mon Apr 03, 2017 5:02 am ] |
| Post subject: | Getaway hull play |
Hi everyone! New to the forum and to hobie cat ownership. Picked up a used getaway a couple weeks ago and Im trying to get it ready for the season. Had some questions about the hulls being loose and twisting. For example if a pick up my port side bow I can lift it a good amount before my starboard side lifts with it. I can see the rear x-bar rotating in the hull molding. Is this something that will be reduced once a step the mast or is there something I should do? (shimming) I don't see any cracking around the molding that I've been reading about. I believe the boat is a 2010. Thanks! |
| Author: | kevinbatchelor [ Wed Apr 12, 2017 11:13 pm ] |
| Post subject: | Re: Getaway hull play |
I have a 2010 (I think), I don't think I have that much play in the hulls. You could always tighten up both tramps and see if helps. |
| Author: | tpdavis473 [ Thu Apr 13, 2017 7:31 am ] |
Do you have the front tramp installed? I have my front tramp installed and there is about 6" of lift before the other bow lifts if I lift one bow. It's not a stiff boat. |
| Author: | mmiller [ Thu Apr 13, 2017 8:24 am ] |
chincoteaguesailer wrote: For example if a pick up my port side bow I can lift it a good amount before my starboard side lifts with it. I can see the rear x-bar rotating in the hull molding. Is this something that will be reduced once a step the mast This is normal for a Wave or Getaway. It will stiffen up with tighter trampolines and with the rig up and tensioned. It will still "rack"... as you lift a bow the other is not going to come up at the same time. |
| Author: | chincoteaguesailer [ Thu Apr 20, 2017 2:10 pm ] |
Thanks for the responses! I ordered new ropes for the tramps to tighten everything up because the ropes that are on there are a little jury rigged. |
