| rightening http://www.hobie.com/au/en/forums/viewtopic.php?f=23&t=68185 |
| Author: | Paolo.ruggieri [ Thu Apr 15, 2021 7:24 am ] |
| Post subject: | rightening |
All, It seems that I always need 420 pounds to righten the getaway.... which means I can't sail the getaway alone (I am 190lb)... not even with my 150 lb son, nor with my 110 lb daughter... We end up always needing to be 3+ people? I see a lot of Hobie 16 videos on the bag system, but none on getaway. Does anyone have a proven system to righten getaway solo with a bag system? Where do you hook the bag? What is the minimum weight you need to righten the getaway? thank you, Paolo |
| Author: | BRinSCupstate [ Thu Apr 15, 2021 12:07 pm ] |
| Post subject: | Re: rightening |
Take a look at this: https://www.hobie.com/forums/viewtopic.php?f=23&t=60438&hilit=righting+board Below is a video of righting a Getaway solo using the righting pole. There are also some details about building the pole further down in the above series of posts. https://youtu.be/eHvCGd8DkD0 |
| Author: | speed633 [ Thu Apr 15, 2021 6:13 pm ] |
Shroud Extenders. I have them on my 21SC and can easily right the boat with 320lbs. |
| Author: | Smofa [ Sat Apr 17, 2021 2:47 am ] |
I use a righting bag from Murrays https://www.murrays.com/product/01-3280/ |
| Author: | Paolo.ruggieri [ Sun Apr 18, 2021 10:59 am ] |
Where do you hook the bag? |
| Author: | Steve C [ Sun Apr 18, 2021 1:43 pm ] |
Have the mast at a 45 degree angle into the wind with the wind hitting the front of the mast. Even a very light wind will get under the sail. Practice in a out of the way area. You will get dialed in. With 1 kid will be easy, by your self should work ok as long as you have the mast positioned good. |
| Author: | Paolo.ruggieri [ Mon Apr 19, 2021 6:44 am ] |
Anyone willing to share a video of rightening a getaway with a bag? |
| Author: | dorienc [ Mon Apr 19, 2021 9:46 am ] |
I don't understand. I'm 200# and can right the boat myself. I once capsized with my wife, and she did most of the work herself, I don't think I loaded more than 50# on the righting line. And she's pretty little. I use the supplied righting line, no righting pole. |
| Author: | Steve C [ Mon Apr 19, 2021 6:42 pm ] |
https://lh3.googleusercontent.com/ztLJo ... authuser=1 Don't have a video but I'm 190 #, as as long as I have the mast into the wind so the wind gets under the sail it's pretty easy. https://lh3.googleusercontent.com/hD8j_ ... authuser=1 |
| Author: | NOLA sailor [ Tue Apr 20, 2021 12:45 pm ] |
Paolo.ruggieri wrote: Anyone willing to share a video of rightening a getaway with a bag? Not a Getaway, but same idea... https://www.youtube.com/watch?v=1UyUZOP94-8&t=340s |
| Author: | Smofa [ Sun Apr 25, 2021 5:03 pm ] |
Paolo.ruggieri wrote: Where do you hook the bag? I tie it to the mast base stud. The bag is strapped on the front tramp, when capsized, I throw it over the hull in the air. |
